- May 20, 2012
So, i am looking at cooling my GPU along with my CPU. The case i have right now, a slightly modded HAF932 (essentially just the case, no front I/O) has only room for one 360rad.
I will also be upgrading my system to a 5930k or if i can the 5960x within the next 6 months, along with a second GTX 980 (aiming for some sweet 4k gaming)
To that end, and wanting near silent computer as it is in my room that i sleep in and i need to keep it on 24/7. i run a massive plex media server along with plenty of video/picture editing, autocad/inventor designing, and random programming. i want the fans to run at no more than 1400RPM. Looking at martins liquid lab, the 360 version of that rad will dissipate 210w at that fan speed, times that by 4, i can plan to dissipate 840watts. I would start with just 1 480 and my existing rad, and upgrade the rads one i upgrade the CPU/GPU. I figure at most the 5960x would produce 275W (aiming for a high OC), and each GPU OC'ed would be in the range of 200-215w.
My specs i will be going with are the following;
Specs i am undecided about;
The resi is more a pure aesthetic design, while the pump i am unsure about.
I am looking at the MPC655 variable speed, but might want to go with a pump that i can attach a tube resi to. Otherwise i am looking at mounting a free standing resi inside the rad box, with a pump on each side.
My question is this, will one pump be enough for that loop, or will i be looking at two? Plus suggestions on a block pump would be appreciated.
The rad box will have its own fan controllers (SEN-MIX2-M1), PSU (probably my old CM 850 wired up to an awesome looking switch), with two tubes running to the back of my case with quick-disconnects.
I am working on a design right now and will update this one i get further for others to use as a resource.
- 3x Alphacool NexXxoS UT60 480mm
- EK block i have in sig for proc
- EK block for GPU's
- EK block for Mosfets
- Resi
- Pump
- Fans, Right now i have 6xSP120s on my rad and i get ok temps, idle broswing 25c, load 55-60c. Might just keep with those, unless there is a better fan for around the same price as those. I can get a twin pack for 22 bucks at my work.
