@Sebastian
the reason that the controller looks so clean and sexy, is because bing take the pics of it
guess playin' simcity a long-long time ago pay me back for this layouting stuff
A bump just to brag on a gift that I just received from inVain, an excellent built of the 0-100% version pwm controller.
<SNIP>
Imo, this is a work of art, very nicely laid components !
<SNIP>
Thank you inVain, really honored to have this piece of fine work of yours.
With a little bit of help I now have two 15.6khz PWM outputs from a $2 attiny85!
Now it's time to make a little box for it to sit in and put a couple headers on it.
Now I can make fan controllers with any pot I particularly want to, or even a 20 turn trimmer! Though that would be silly, as there are only 256 steps to the PWM output.
@Jalyst
I afraid that I can't accept the contract sir
especially I ain't no EE student,
frankly speaking I can only create those clean layouts when I'm in the good mood
but if you like the controller that I've already build and posted the pic here (if I still had it one piece of course, and lying around outside my PC case ) then you can have it...
though I'm not really sure how to send it across the ocean
I've read your thread but I can't understand it thoroughly...
but I can see that you want a multiple channel fan controller and mixing for 3 and 4 wire fans....
well, personally, I don't like the 3 wire fans anymore because of their lack of efficiency to be used in PC.
I'm sorry, but building a 3 wire fan controller will be my last priority project
but, if you want a 4 wire controller wich will be able to control multiple fans independently, than I hope what I've build recently may inspire you (I not really sure tough)
Something you might try jalyst, is posting on the Arduino forum (arduino.cc), someone there may have a bright idea or two for creating something along the lines of the BigNG but cheaper and to your specs.
I'm interested in the concept too as I have a delta 252cfm beast that doesn't accept PWM control, I'd like to be able to turn it down a bit.
If I find something worthwhile I'll let you know.
and here what I hook up with that controller (2x delta FFC1212DE on the top and bottom front, 1x delta PFC1212DE on the ven-x):
.snip.
I connected the 2x FFC in series with one 2-98% on the board, and the PFC on the other one, so I can run the FFC at different speed than the PFC
The MCU is mostly alive, only pins 3 and 4 fried. Unfortunately pin3 is both a PWM pin (one of six) and one of only two interrupt pins, so it's a bit of a loss. On the plus side, it's a $4 MCU and I am set up to burn new bootloaders via ISP. I'm trying to convince Atmel to send me a stack of a few different types of MCU for me to try out fan controllers with, if they do it I'll be very happy!
@Bing:
I tested it with a 2X 3900 rpm Delta and 2X1500 rpm Gelid fans simultaneously. It worked well for both setups.
Just wanted to thank everyone for the help and comments. It's been running trouble free for a few days now so I'm really happy with it.
@Bing:
That is one hell awesome cpu cooling power and air flow you got there.
To others that still wondering why I called this awesome power, that 3 delta monsters when at their max speed are sucking power almost at 100 watt !!!
Say if they're running at their rated 90% speed, prolly still consume somewhere about 70 to 80 watt, and this is important, their power efficiency will still at a very high level, maybe > 95%.
When it comes to handling high power fan, this is one heck of the proof that pwm fan is a lot better than classic 3 wires fan. You won't find any off the shelf fan controller out there that can handle this kind of load on "single channel" or single pot.
Really awesome inVain !
Trust me, if that circuit is supplied with proper working voltage and also properly connected to a normal working pwm fan, it will last for a very long time, the only failing part is probably the pot since its mechanical.
I guess you could even pass it to your grandchildren, assuming they're still playing with this kinda stuff in the future. LOL .. ..j/k
Quick poll time (for anybody who reads this thread):
For a dual output fan controller (that's two PWM speeds, not necessarily only two ports, it could be four or six or more ports), would you prefer two knobs, or up/down buttons and an LED to indicate which fan you're controlling? Either one is quite doable.
Another possibility is a temp sensor on wires that you place in your case's exhaust stream, and then tell the controller what the max and min temps you want are. The downside is that telling it the temps via three buttons and two LEDs (or some combination using five pins) is likely to be a bit tedious. I could use a 328 for that and have lots of input, but that goes from $2 mcu to $5 mcu.
