- Dec 10, 2011
- Cádiz (Spain)
Replace the 470pF capacitor with a 680pF one, IIRC.
I haven't noticed anything like that in my oscilloscope testing. I won't say it is impossible, but I will say it is unlikely.
You're not going to see anything physical, far too much inertial for that.
If you're talking physical wear, I say no way.
Do you happen to have a drawing of that setup available? Currently I have the dual 555 circuit setup with reverse Schmidt buffer (from here) on my breadboard and my 260 cfm San ace 12v 4a is of its way in the mail. I'm curious as to what I have to change to be able to run from 0-100 at 16khz as you are doing.
Thanks so much for the information!
On my experience the san ace 12V 4A 260cfm works well even at 25 Khz. No difference between 16 Khz and 25 Khz signal noticeable.
For the circuitry schematic have a look right here.
forget building the 2-98% if you're aiming to control the SG...
it's whining noise was unbearable, even if you set it at 16Khz
yep, I'm now running the 0-100% with multiple 555 and no more noise issues
he're what I've got to tame the puppies
for 16Khz signal, try to use 820pF to substitute the 560pF C1 on the 0-100% schematic,
as in my case, I use the 560pF in parallel with the 220pF to get the closest result (I'm out of luck to get the 820pF )
Wow... The 0-100 dual 555 with opamp works amazing in my simulator. Is there any reason a 556 couldn't be used in place of the two 555 ic... I have one laying around. I'm no expert in electronics so please forgive any stupid questions I may have.
I'd bridge the two ground wires just for good measure. I've found as much as a 0.13v difference between a Molex ground pin being used by a Fan and one not being used.
That shouldn't be enough to cause issues, but you never know.
Do you have PCB manufacturing supplies or do you have it done somewhere? I've always thought it'd be fun to do yourself.
They are pretty easy o make yourself. My wife went to a technical school for engineering during high school, before she went to university and became an English professor. She helps me make all of my electronics.
Really envy you on the wifey thing , anyway, hope everything will run smoothly and expecting some pics for the finished circuit.
