Fans are here and intense. Next up for the electronics manufacturing division is a fan pressure measuring system
Just finished this:
The three outputs go to the fan connector on the right for easy plug'n'play.
On a multimeter they do exactly what I expect them to, tomorrow I'm going to go get my PWM fan as well as plug this thing into the scope and see what things look like.
I should be able to trace all three PWM outputs at the same time... I'll get a pic of that if I remember to bring the camera.
EDIT:
The smaller black electrolytic isn't on the schematic, I added it cause I had room and have a bunch of 'em. Certainly won't hurt.
2.EDIT:
Ignore the wire color on the molex, it was originally a fan adapter, I moved the pin from 12v to 5v, but changing the wire color is somewhat harder.
3.EDIT: The pressure system will be a box, likely cardboard, that the fan attaches to. In this box there will be a hose, the hose will lead to a fairly sensitive pressure sensor ripped out of a cavalier fuel sending unit when the pump died, read by an Arduino clone (BBB or RBBB) and fed into the computer from there. Or maybe into a 2x7 segment display if I get off my tail on that one.
4.EDIT: Neither fan is PWM, despite the Nidec having four wires. Donno what wire #4 is.
Given the frustrations outlined in this thread: http://rog.asus.com/forum/showthrea...reme-PWM-control-Fan-outlets&country=&status= I have ordered all the parts to build my own.
I'm considering adding 12 more fans (an upgrade to push-pull) and I'm wondering if you think the controller could handle it? Let me know
Hey guys, whats up? Its been a year and a half since you built this for me Ed, and I'm happy to report that it is still working perfectly, thanks again
OK thanks guys....I'll let you know if I decide to do it
Also, I have not been following fans lately....is it still possible to get the non-PWM Scythe GT fans and mod them for PWM?
thanks for all of your supports
well it's a little bit shameful, but can anyone show me how to determine the polarity of an smd led, since they really look identical on both of it's end
take your multi meter and put it on the continuity setting and touch the leads one way if it shows current traveling then its right the red is positive and black is positive
