- Apr 20, 2008
- Toronto, Canada
Looking to purchase a new case to replace my generic one, its too small to hold a GTX 260 with hard drives getting in the way. Currently I can purchase the CM690 for $115 (taxes and shipping).
CM690 specs:
Scout specs:
Is it worth the wait and extra money or should I just grab the CM690? Which is a better case for air cooling?
CM690 specs:
The Coolermaster Scout seems to be a nice case too. I prefer the all black interior and better build quality than the CM 690. Its gonna be released on May 5th for about $135CAD. One thing I dislike about it is that there is not much clearance for a bottom-mounted fan on PSU.Chassis Appearance: Black
Drive Bays 5 Exposed (without the use of exposed 3.5 inch Drive Bay),4 Exposed (with the use of 3.5 inch Drive Bay)
Material Chassis: SECC, Bezel: Metal mesh+ABS
Form Factor ATX, Micro-ATX
Expansion Slots 7 standard slots
Case Fans Front: 120 mm Blue LED fan x 1, 1200 rpm, 21 dBA,Rear: 120 mm standard fan, 1200 rpm, 21 dBA,Top: 120 or 140 mm fan x 2 (optional),Bottom: 120 mm fan x 1 (optional),Left: 120mm fan x 2 (one is optional)-up to 140mm fans
Dimensions (W)213 X (H)482 x (D)524.5 mm
Weight 9.8 kg
Front I/O USB 2.0x2, IEEE 1394 x1, MIC x1, eSATA x 1,SPK x1 (support HD Audio)
Scout specs:
* Color: Black
* Material: Steel, ABS Plastic, Mesh Bezel
* Dimensions: (D)489 x (W)219 x (H)495.5mm / (D)19.2 x (W)8.6 x (H)19.5in
* Weight: 8.7 kg / 19.23 lb
* Motherboard Compatibility: Micro-ATX, ATX
* 5.25" Drive Bays: 5 Exposed (Without the use of exposed 3.5" drive bay)
* 3.5" Drive Bays: 5 Hidden (HDD); 1 Exposed (converted from one 5.25" drive bay)
* Front Ports: USB x 4, eSATA x 1, Mic x 1, Audio x 1
* Expansion Slots: Standard x 7
* Cooling System:
o Front: 140mm Red LED Fan (Included) or 120mm Fan x 1 (optional)
o Top: 140mm Fan (Included) or 120mm Fan x 1 (optional)
o Side: Transparent window; Supports 120mm Fan x 2 (optional)
o Rear: 120mm Red LED Fan (Included)
* Power Supply Compatibility: Standard ATX
