- Sep 10, 2016
I want to downsize my rig. Its takes up a lot of space. I have never had a micro case before and I am seriously giving thought to a micro-ATX.
I don’t need a full overclocked gaming rig. I do like to use 3D animation software so a little graphics beefy.
So what I am hoping to do is get a small case. It has the following specs:
Dimensions (WxHxD) 250 x 404 x 359mm
Motherboard Sizes Micro ATX, Mini-ITX
5.25” Drive Bays x 1 (removable."if install an ODD,can not install an HDD on the top position of the HDD rail")
3.5” Drive Bays x 4 (x3 with ODD installed)
2.5” Drive Bays x 5 (3 + 2)
Cooling Top 120mm x 2 (optional)
Cooling Bottom 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
Cooling Rear 120mm x 1 (included) or 140mm x 1 (optional)
PCI Slots x 5
I/O USB 3.0 x 2, HD Audio
Power Supply PS2 ATX (bottom, multi direction)
Extras FyberFlex™ Composite handles, SofTouch™ surface treatment, heat shield
It’s called a BITFENIX Prodigy M.
My current rig has the following...
description: Motherboard
product: DZ77SL-50K
vendor: Intel Corporation
*-memory
*-bank:0
description: DIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: 99U5471-039.A00LF
vendor: Kingston
*-cpu
description: CPU
product: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
vendor: Intel Corp.
*-display
description: VGA compatible controller
product: GM107 [GeForce GTX 750 Ti]
vendor: NVIDIA Corporation
*-disk
description: ATA Disk
product: INTEL SSDSC2CW24
description: Wireless interface
product: AR93xx Wireless Network Adapter
vendor: Qualcomm Atheros
So if I get this mini-ATX I am hoping to then get a new motherboard and just switch this hardware into it.
So if the above config seems still good to go, what motherboard?
PCI Slots x 5
product: DZ77SL-50K
*-memory
*-bank:0
vendor: Kingston
*-cpu
description: CPU
vendor: Intel Corp.
*-display
*-disk
