FYI for those that can read and assimilate...
I likely have written part of this before but as time has passed there is more information available as more testing is done by various sites and venues.
I really hate burying this stuff but a few will see this and know accordingly.
http://www.intel.com/content/www/us...ces-xeon-measuring-processor-power-paper.html >>
Measuring Processor Power TDP vs ACP
http://www.anandtech.com/show/2807/2 >>
Making Sense of AMD ACP/TDP and Intel TDP
Now you want to know why AMD FX processor can run so hot? You can take the charts at link below and see (within that PowerSupplies Accuracy) what an FX-4core or 6core or 8core processor actually draw for power from the power supply.
http://www.xbitlabs.com/articles/cpu/display/fx-8350-8320-6300-4300_8.html
performance analysis of all Vishera processors with eight, six and four cores.
Power measured on the output of power supply not the input side.
Now while you are doing the math gymnastics above, do nOt forget the stipulation from that test/article what have you. There is no way the tests at their tested "full load" are drawing the power that most of us would see when we lock our cpus into ALL cores on and WFO. A huge difference between our overclocked ALL cores on and testing power draw at output of the P/S at full load with the cpu setup as tested by Xbitlabs. Period.
Copied:
The CPUs are loaded by running the 64-bit version of LinX 0.6.4-AVX utility. Moreover, we enabled Turbo mode and all power-saving technologies to correctly measure computer's power draw in idle mode: C1E, C6, Enhanced Intel SpeedStep and AMD Cool’n’Quiet.
End Copy.
From AMD PDF about Turbo Core Technology.
AMD Turbo Core Technology: AMD Turbo Core Technology and Application Power Management (APM) allow the CPU cores to run above the CPU Base clock value as long as the CPU remains within the thermal and power limits.
As an example the AMD FX-8150 CPU has a base clock of 3600MHz but it can run at 3900MHz when up to 8 cores are active and at 4200MHz when up to 4 cores are active assuming it stays within the power and thermal limits.
Under very heavy workloads the CPU will return to the base clock – 3600MHz in the case of AMD FX-8150 CPU.
Remember when we overclock, it is general practice to disable TurboCore etc so that in our overclocked state the processor normally is running ALL cores enabled and at the overclocked speed.
RGone...ster.
