- Dec 6, 2013
- Baden, Austria
Hi,
during playing around with my setup and trying to find a good cooling solution for my VRMs I was going through the vast amount of different designs and materials available for cooling blocks.
My plan was instead of going for standard coolers that fit to the Mosfets and chokes I wanted to use the available area around the VRM modules to maximize the surface area for best possible heat dissipation. So I knew the base area of the cooling block and I knew that its pretty unlikely to find a single piece of block with the required dimenstions and shape for that spot. So I have to buy a block and cut it into shape.
The question was, which design will give me the largest surface area for my given base area that I can cover on my motherboard.
For a certain block u usually get the dimensions (mainly base area) and the thermal resistance for that specific block which is determined by the material, coating and its dimensions.
Ok. what if I have a 6x4cm with R(th) of 2 and a 15x10 with R(th) of 0.7 and and and. Which one has the largest overall surface area per unit base-area?
I made an excel sheet, entered the length and width (to calculate base area A) and R(th) of all the different products and calculated: 1/[R(th)*A] for each.
Of course it is not a 100% accurate result because the very limited amount of parameters required simplifications but it still works very nicely.
For example it sheds a new light on certain copper heat sink designs and their price compared to other materials and designs.
If you are interested in the rational behind the calculation just ask. Else, just use it and see the difference.
Chris
Edit: i apologize, my english is más o menos - instead of cooling block please read heat sink.
Chris
