im running a NEW (built today) i5 2500k cpu, stock heatsink, on MSI P67A-G43 (B3).
i want to upgrade the stock heatsink to the xigmatek loki sd963 seen here. the xigmatek comes with 92mm fan. will i be able to fit a 120mm fan on there or is it built specifically for 92mm fans? and regardless of fan size, can i install a second fan for "push-pull"?
sooner or later i know someone will recommend gaia instead, but i want to know my questions first before considering gaia.
thanks
thanks
