Unless you have an adapter card you won't be able to use the wireless card.
You wouldn't want to anyway, because the laptop wireless would be lower power and most likely built to take advantage of two antenna. You are better to get a full power wireless adapter card or one of those usb wifi sticks ($20).
I'd grab an old router/AP and set it to bridge mode. Then run a cable to it and duct tape the unit to the inside of your case. ( That way it'd be internal wireless. )
