- Jul 15, 2013
ok so heres the dilemma im in. i recently upgraded to an all in one liquid cooler for my hp Z400 desktop, and the power connector for the pump doesnt reach the cpu fan power header so i was wondering if i could use the 4pin fan splitter i have on my AIO liquid cooling pump so that the pump can reach the correct header. as u can tell from the pic of my pump it has a small extension cable with a 5th wire that 5th wire is designed to tell the computer that im using a high powered cpu fan for my 6 core xeon cpu.
Everytime I boot up the PC it says: "517-Low Power CPU Heatsink(s) detected for High Power CPU(s)"
the motherboard is seeing no ground contact at pin 5. The Performance fan has a ground jumper wire from pin 1 to pin 5.
right now i have the pump plugged into a 4pin header but because of this the 5th wire isnt able to tell the mobo that im using the correct heatsink for my cpu can i use the 4 pin splitter on my AIO pump since it has a separate plug as seen in the pix below
dont wanna ruin or damage my aio setup
