By simply disabling the floppy in BIOS, you can assign either A or B to an internal hard drive in Windows 7.
But I guess not in Windows XP?
Do you have the floppy's disabled in the bios?
...but if you only have one floppy, can you free up drive letter B: and still keep A: assigned to the one floppy drive you have?
A: is reserved for first floppy and B: for second floppy, but if you only have one floppy, can you free up drive letter B: and still keep A: assigned to the one floppy drive you have?
You should be able to. I'm using windows 7 ultimate 32bit and I have my 1TB hard drive in 3 partitions:
On Windows XP Professional SP3, I just assigned my flash drive to the A drive.Are you using XP? I'm not sure if there is a work around but by default you can't use A or B for anything other than floppies.
microsoft.com said:You can assign the letters C through Z to each drive on your computer. A and B are usually reserved for floppy disk drives, but if your computer does not have floppy disk drives, you can assign A and B to volumes. You can see which drive letters are used on your computer by opening Computer.
That's a negative. See post #13 of this thread.
http://www.edugeek.net/forums/hardware/24355-forcing-usb-floppy-drive-assigned.html said:There were 2 separate points in the BIOS that I had to change - it may depend on your PC, but I had to disable the floppy disk controller (FDC) on the onboard devices screen and also set both A: and B: to None on the disk setup screen. Obviously that will vary from BIOS to BIOS but if you're struggling to follow my clear as mud explanation I can take some shots.
