- Thread Starter
- #21
I hope so too, xrror.
This is what is weird. The following settings are what i'm testing at the moment:
BCLK = 192
Multiplier = 21 (EIST enabled)
Memory Ratio = 5 (to get DRAM 1920MHz)
Uncore Ratio = 10 (to get 3840MHz ; double the RAM value)
QPI Frequency = 4.800GT (resulting in QPI Frequency @ 6912MHz)
QPI Voltage = Auto (don't have a program to determine what it's set to but if I follow MSi Control Center it's 1.59)
PCI-E Frequency = 100
DRAM Voltage = 1.65
CPU Voltage = 1.336 (will work on trimming this a little more if possible)
With these settings my system is rock solid. Prime95 churns with no problem, LinX processes max memory available with no freezing or stuttering at all. Not to mention that games are running fine and no crashing whatsoever.
It's an odd feeling at this point....one of the main reasons I started investigating my systems instability was due to the fact that I would get frequent crashes with the games that I play. Since determing the 200x20 with QPI @ 1.65, the very same games do not crash anymore. The only thing bugging me is that Prime95 and LinX crashes; you know, that feeling where you know that the system isn't 100% stable even though it works fine for what you need.
Now I know that media encoding, 3D work and gaming are not gonna push the system anywhere near the extent that LinX and Prime95 do, so i'm contemplating if it is worth really worrying about aside from the fact that the QPI is stupidly high (cause after all my searching on the net i've not seen anyone needing to put their QPI on 1.65) and I don't want to jeopardize my system/CPU if having the QPI so high is an obvious way to do that.
Furthermore, with the above settings which i'm testing, when I reach 193 I start getting few errors within LinX and Prime95....the higher I raise the BCLK the more errors start popping up until I reach 200 where the moment there is an error (in either of them) my system crashes.
So is the BCLK / Uncore at the max for this particular CPU? Or could it be the board? I'm not sure at this point.
But I appreciate all the feedback so far, guys. If anything, i've learned quite a lot about i7's and overclocking....a little different from OC'ing Core 2 Quads.
Still willing to experiment.
EDIT: Another question; with EIST enabled (where C1E and other speed stepping features are disabled) I get an extra core unlocked. So Windows registers 3840MHz but CPU-Z and other diagnostic programs recognize 4032MHz. Now, is my system running at the latter or are there specific conditions before it does? And if so, does it apply to all cores or just the first core?
Again, thanks.
r2rX
BCLK = 192
DRAM Voltage = 1.65
Again, thanks.
r2rX
