Hi all,
I have been testing stability for my new memory setup for a week now and I have to say I'm very tired and dissapointed. As you can see that prime95 only fails the between 10-24 hrs stress. I just purchased my PDP Patriot XBL PC3200 2x256MB kit and running it in slot 1 and slot 3 on my Abit NF7-S v2.0 mobo with Mantaray XT(reflashed from Merlin taipan because of this unstability) After the flash, it failed somewhere around 12 hours on dual channel. So to rule out the memory fault, I ran each module on slot 3 and 1 modules passes prime95 for more than 24hrs straight. The other module failed prime around 15-16hrs. So with this module, I double check it by run it through Memtest86+ default test, not a single error has been found for 24+ hrs.
So can I now rule out my memory? or should I memtest it in dual-channel first? Or your suggestion what to do next? Thanks.
Here's the list of component:
AMD XP-M 2200+ 35W
Abit NF7-S v2.0 with Mantaray XT cpc on
Patriot PC3200 256x2 with XBL technology (slot 1 & 3)
ATI Radeon 9500pro with Warp bios but not overclocking
Seagate 80GB 8mb HD
PC Power and Cooling 310W Silent series
Swiftech MC462+ with Thermaltake SilentCat
Northbridge and Southbridge are all passive-cooled.
2x120mm and 1x90mm with SuperFlower Fan Master
Current setting for each components:
-CPU : 200MHz FSB x 8.5 ; 1.475V (BIOS read 1.46 and 1.45V, AbitEQ reads 1.44 and 1.46V)
-Memory: 200Mhz FSB synchronous; 2.6V (Bios reads 2.61V, AbitEQ reads 2.61)
- VideoCard: no change, stock
-Temperature(idle/load): 38C/42C
AMD XP-M 2200+ 35W
Seagate 80GB 8mb HD
