- Dec 11, 2003
These are my bios settings...
BIOS Version: 1406
CPU Multiplier: 8.5
FSB Frequency : 471
FSB Strap to North Bridge : 333mhz
PCI-E Frequency: 100mhz
DRAM Frequency: 1:1 @ 942mhz
DRAM Command Rate : auto
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
DRAM Static Read Control: auto
Ai Clock Twister : Lighter
Transaction Booster : 10
CPU Voltage : 1.35
CPU PLL Voltage : 1.52
North Bridge Voltage : 1.30
DRAM Voltage : 2.10
FSB Termination Voltage : 1.32
South Bridge Voltage : Auto
Loadline Calibration : Enabled
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
Both CPU and Dram Spectrums: Disabled
CPU Margin Enhancement: Performance
I am 100% ram stable in Memtest at both 3.8 and 4.0 so that isnt an issue for me. The problem is this... I have adjusted the cpu voltage from 1.30-1.40 and prime95 fails within 1-6 minutes. Not even a slight hint that even at 1.4 there would be more stability than 1.3 to say the least. I have also done the same with the NB and FSB voltages from 1.3-1.4... still the same 1-6min fails in Prime95. I have set Transaction Booster anywhere from 10-15 and they all fail Prime95 with the 1-6 minutes just the same. I am absolutely lost at this point as to why that 20 fsb of a difference means a whole lot to 10 hours of Prime95 stability which is what I can achieve at 3.8ghz but not at 4.0ghz.
BIOS Version: 1406
CPU Multiplier: 8.5
FSB Frequency : 471
CAS# Latency : 5
RAS# Precharge : 5
CPU Voltage : 1.35
DRAM Voltage : 2.10
