- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
Hey there, I'm trying to install Windows 7 Ultimate 64-bit on a Lenovo G50-80 notebook that initially had Windows 8 64-bit on it. I have my W7 copy on a USB 3.0 flash drive, and although I'm able to boot from it successfully, when I get to the installation part, I get the "A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now" error.
-I have Legacy Support turned on in the BIOS
-OS Optimized Defaults is set to "Other OS", not "Windows 8" in the BIOS (those are the only two options it has)
-I've tried all three USB slots (only one of them is 3.0, the other two are black-colored so I'm assuming those are 2.0)
-There's no option I see in the BIOS to disable USB 3.0 (although I don't know if that's necessary in this case)
-I've tried installing the Intel 3.0 patch onto the flash drive, which allegedly allows Windows 7 to be installed in 3.0 slots
-I've tried exiting out of the error message, going back and trying again
-I've tried exiting out of the error message, then swapping the flash drive to a different spot
These are pretty much all of the fixes I have looked up, and so far I still haven't had any luck. Does anyone have any ideas? Would using a CD/DVD to install Windows 7 work? Or is this a driver issue that has nothing to do with the USB slots? Thanks for reading.
