- Apr 13, 2004
- Joint Base MDL NJ
I cant seem to get it a hz over 2.2ghz. My load temp never ever goes over 47C, normal load temp is 45c, so I dont believe it is a heat problem. My MB of course doesnt support vcore changing, but I can change the vcore right on the CPU. I am currently running 11x200 at 1.74v. I can P95 for 10+ hours and Memtest for 9+ with those settings.
Once I attempt to put it up to either 11.5x200 or 11x205(cant go anyhigher with FSB cuz board can not lock AGP/PCI) P95 fails after only 10-30 seconds(I also up the vcore to 1.8). I have done hours and hours of "burn-in", both by full vcore and minimal CPU speeds , lowest possible vcore with highest CPU speeds and neither have yielded any progress.
The only possiblity I can think of is my memory, but wouldnt that affect FSB more than multi(I have even tried to put CPU at 18x133 and still nothing over 2.2ghz)? PSU seems fine. So this is the point I am stuck at. Any help from some of you veteran OCers?????
