Hi,
I bought two kits of DDR3 1866 and can't get it running at 1866MHz.
Kits:
HyperX Savage 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
HyperX Savage 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
Same specs, same timings, voltage... everything matches.
Motherboard: ASUS P6T7 WS SC
CPU: Xeon X5690
I tried XMP, but that didn't do anything. Shame for the extra price!
How do I get those sticks to run at 1866? I'm OK with a bit extra CPU OC (4 - 4.2 GHz), if needed.
Right now the memory boots by default at 1333.
There are 2 XMP profiles, at 1600 and 1777 those won't boot at all, I can't even see the BIOS' initial message screen.
I see my motherboard key looping between two codes, which change so fast that I can't tell what the error codes are.
Kits:
CPU: Xeon X5690
