okay guys here you go
*please* post if anything is not 100% clear.
You should be able to install this OFFLINE, and the first time you try to access Windows 7 Update, it should only list 2016 May updates and later:
Windows 7 SP1 Convenience Rollup contains all the security and non-security fixes released in more than five years since the release of Windows 7 Service Pack 1 in February 2011.
Here's how to make a single installation ISO which includes all Windows 7 updates up to 2016.
https://blogs.technet.microsoft.com...17/simplifying-updates-for-windows-7-and-8-1/
gives a download link which only works with Internet Explorer and not other browsers:
http://catalog.update.microsoft.com/v7/site/Search.aspx?q=3125574
[You need to install the Microsoft Update Catalog Add-on to be able to Add the downloads to download "basket"...]
Update for Windows 7 (KB3125574) 5/16/2016 316.0 MB
Update for Windows 7 for x64-based Systems (KB3125574) 5/16/2016 476.9 MB
• April 2015 servicing stack update for Windows 7 will be required:
https://support.microsoft.com/en-us/kb/3020369
• Windows Automated Installation Kit (AIK) for Windows 7 will also be needed:
https://www.microsoft.com/en-us/download/details.aspx?id=5753
Now rename and copy all the files from above to folder C:\Updates:
• 64-Bit April 2016 Windows 7 SP1 Convenience Rollup update file (KB3125574):
AMD64-all-windows6.1-kb3125574-v4-x64.msu
• 64-Bit April 2015 Servicing Stack Update for Windows 7 file
Windows6.1-KB3020369-x64.msu
• 32-Bit April 2016 Windows 7 SP1 Convenience Rollup update file (KB3125574):
X86-all-windows6.1-kb3125574-v4-x86.msu
• 32-Bit April 2015 Servicing Stack Update for Windows 7 file
Windows6.1-KB3020369-x86.msu
• Windows Automated Installation Kit (AIK) for Windows 7 file
KB3AIK_EN.iso
0. Download Windows 7 + Service Pack 1 integrated Disc Images (ISO Files) from
https://www.microsoft.com/en-us/software-download/windows7
1. Extract Windows 7 + Service Pack 1 iso to C:\Win7SP1ISO
[Look up how to extract contents of an .iso file if you don't know how.]
2. Make a new folder C:\Win7SP1ISO\offline
3. Make sure that Windows 7 SP1 convenience rollup .msu file and April 2015 servicing stack update .msu file are in C:\updates
4. Run this command from DOS as an Administrator:
Dism /Mount-WIM /WimFile:C:\Win7SP1ISO\sources\install.wim /Name:"Windows 7 ULTIMATE" /MountDir:C:\Win7SP1ISO\offline
If you have a different version of Windows 7, then replace the word ULTIMATE with the version of Windows 7 you have.
If you do not know which version of Windows 7 you have, use this command to see what is next to Name:
Dism /Get-WIMInfo /WimFile:C:\Win7SP1ISO\sources\install.wim
5. Integrate Servicing Stack Update:
Dism /Image:C:\Win7SP1ISO\offline /Add-Package /PackagePath:C:\updates\Windows6.1-KB3020369-x64.msu
Change name of .msu file if you are integrating a 32-bit / different version file:
Dism /Image:C:\Win7SP1ISO\offline /Add-Package /PackagePath:C:\updates\Windows6.1-KB3020369-x86.msu
6. Integrate Convenience Rollup update package:
Dism /Image:C:\Win7SP1ISO\offline /Add-Package /PackagePath:C:\updates\AMD64-all-windows6.1-kb3125574-v4-x64.msu
Dism /Image:C:\Win7SP1ISO\offline /Add-Package /PackagePath:C:\updates\X86-all-windows6.1-kb3125574-v4-x86.msu
[This step takes a while.]
7. Commit the changes and unmount the image:
Dism /Unmount-WIM /MountDir:C:\Win7SP1ISO\offline /Commit
Create a new Windows7Updated.iso installation which will include all updates through April 2016:
8. Download and install the Windows Automated Installation Kit (AIK) for Windows 7 on Windows Vista/7/8/10:
Select Windows AIK Setup to install.
9. Start > All Programs > Microsoft Windows AIK.
Run Deployment Tools Command Prompt as an Administrator.
oscdimg -m -u2 -bC:\Win7SP1ISO\boot\etfsboot.com C:\Win7SP1ISO\ C:\Windows7Updated.iso
