Having actually soldered a heat sink to my test block I can tell you it outperforms ASGIII by a wide Margin. It appears that she also ran the same test and was 33% better.
Just because her baseline material comparison was not your prefrence does not make it any less valid.
Chung besides a solder junction comparison, also compared other graphite material some of which are probably close to copper. (do a google on graphite heat sinks = to copper)
do a google on carbon black, it can be bought - try you copier toner .03 particle size
"All thermal pastes previously reported are inferior to solder in providing high thermal contact conductance. By using carbon black as the thermally conductive ingredient, we have attained thermal pastes that are superior to solder in providing high thermal contact conductance."
conductive solid
0.46 MPa
0.69 MPa
0.92 MPa
Carbon black
18.94 „b 0.60
24.87 „b 1.00
25.74 „b 1.20
Graphite (5 ƒÝm)
3.03 „b 0.09
3.67 „b 0.08
4.02 „b 0.12
Graphite (1 ƒÝm)
1.52 „b 0.03
1.77 „b 0.04
2.04 „b 0.05
Nickel (3 ƒÝm)
1.85 „b 0.05
2.14 „b 0.02
2.84 „b 0.04
Nickel (1 ƒÝm)
0.91 „b 0.07
2.03 „b 0.10
2.66 „b 0.03
Diamond (25 ƒÝm)
1.15 „b 0.02
1.21 „b 0.09
1.54 „b 0.03
Carbon filaments (0.1 ƒÝm diameter)
1.09 „b 0.03
1.32 „b 0.02
1.51 „b 0.03
Single-walled carbon nanotubes*
13.5 „b 0.2
13.8 „b 0.3
14.1 „b 0.4
conductive solid
0.46 MPa
0.69 MPa
0.92 MPa
Carbon black
18.94 „b 0.60
24.87 „b 1.00
25.74 „b 1.20
Graphite (5 ƒÝm)
3.03 „b 0.09
3.67 „b 0.08
4.02 „b 0.12
Graphite (1 ƒÝm)
1.52 „b 0.03
1.77 „b 0.04
2.04 „b 0.05
Nickel (3 ƒÝm)
1.85 „b 0.05
2.14 „b 0.02
2.84 „b 0.04
Nickel (1 ƒÝm)
0.91 „b 0.07
2.03 „b 0.10
2.66 „b 0.03
Diamond (25 ƒÝm)
1.15 „b 0.02
1.21 „b 0.09
1.54 „b 0.03
1.09 „b 0.03
1.32 „b 0.02
1.51 „b 0.03
13.5 „b 0.2
13.8 „b 0.3
14.1 „b 0.4
