- Jun 26, 2016
- Adelaide, Australia.
Having a major case dilemma at the moment, so I thought I'd ask for some peoples general thoughts on the cases I'm looking at.
About to start on a water cooled X99 build (black and white) but I am torn between a few cases and am struggling to make a decision one way or the other.
PC Parts -*https://www.pccasegear.com/wish_lists/506120/2016 Build*+ SLI 980's, some SSD's,*HDD's, Xonar STX.
Water Loop -*https://www.pccasegear.com/wish_lists/596419/Cooling loop*So *pretty thick radiator.
Cases I've been looking at, unless people have other suggestions? These are going on a scale of form Vs function from one extreme to the other.
https://www.pccasegear.com/products/33773/in-win-909-aluminium-full-tower-case-black
Pros - Looks great, built really well, in stock at my local shop.
Cons - Heavy (20kg) which, after water cooling etc is in, will suck to drag it to the shed to clean it. Cooling seems like it would be an issue, especially if expanding the loop since there ate only really 2 intakes which would then be filling the case with hot air. No fans, so that is another $100 in fans, but 2 of them could be used on 240mm rad down the track. Power button being on the bottom would be somewhat annoying to turn on and off (spine injury). No PSU cover. No rubber grommets for cables so have to maybe make them, unless it looks ok without them. Reservoir mounting wont be easy, pretty sure I'd have to do a tight 90 degree mount off a front fan.
https://www.pccasegear.com/products/35803/be-quiet-dark-base-pro-900-silver
Pros - Cheaper than 909. More conventional lay out so cooling in general would be easier. 3 included decent fans, so would need to buy less extras and a nice fan controller. Quiet, would be very nice as this PC is going to end up in cinema. Looks decent, not amazing, but not bad. Lighter than the others at around 14kg. Comes with Reservoir mount and some LED strips, not sure I'd use them, but nice to have the option. Power button on top. Flippable motherboard tray is interesting, not sure I'd use it, but could make for a more interesting design.
Cons - Looks ok, but not as good. Large cut out areas which let you move the tray up and down means there are large exposed areas which cables will stick out unless I make grommets. The PSU extender thing is........ weird, also still no PSU cover (is it not 2016, are we still animals?).
https://www.pccasegear.com/products/30484/phanteks-enthoo-primo-ultimate-chassis-black-white-edition
Pros - Cheaper again. Best set up possible for water cooling really. Segmented case to hide PSU, water pump, etc. More HDD / SSD bays than you could poke a stick at. 5 included decent fans and fan controller. Fits with the black and white build idea, though maybe black internal would be a better idea to avoid too much white? Built a PC for a friend last week in a Phanteks case and I have to say I was really, really impressed. Million filters and should be pretty silent. Would have enough space internally for all the media storage on earth.
Cons - Not a fan of the look, just looks kind of old now. Heavy........... gonna be way heavy.
Extra case.
https://www.inwin-style.com/en/gaming-chassis/509*Out in August......... could maybe wait.
Pros - Looks good, take 2 x 360mm radiators. Build quality should be good. Something reasonably unique. GPU support brackets are a nice touch.
Cons - Not out yet. I haven't quite worked out the best way to best get air in / out of one. Not sure I've the patience to wait that long.........
Sorry for the long post, cheers for any input.
Extra case.
