Hey guys,
Just wanted to write short story about a little thing I found out when cleaning my PC case, and hear what you guys have to say about it - science wise!
I'm running a X79 system - 4930k @ 4.6GHz, Cooled by Corsair H80i, 4x4 DDR3 CL10 2133 Ram, MSI 1080 Gaming X, inside a Thermaltake Element S case! I'm generally happy with this case as even though it's old, it looks kick-*** and helps keep my system cool (CPU about 73c during RealBench, GPU about 69c during Heaven/gaming). Everything works perfectly, except a minor thing, which I'll discuss now!
My fan orientation is slightly different than what is shown in the official thermaltake picture (Shown here): I have two front 120MM intake fans, a 200mm side intake fan (not shown in the image), one 60mm rear-bottom exhaust fan, and instead of the rear-top 140mm exhaust, I have the h80i Radiator mounted, push-pulled by two 120mm fans. As for the top fan (230mm) shown in the image... I've had this case for a while, and only yesterday I found out that rather than exhaust, the top fan actually intakes . I tried rotating it for exhaust, just for fun, but found out that it created some problems:
1. The fan has mounting holes on only one side, so I need really long screws in order to mount it as exhaust.
2. The fan generates much more noise when used as exhaust rather than as intake.
I guess #1 can be solved... just need longer screws. #2 though, I understand why the fan generates more noise, it tries to exhaust through cover. It's not a faulty fan, any other fan I placed there also whined because it's trying to pull air out of a metallic grid that is too tight.
So I guess my question is, how critical is it in your opinion? Not sure if I feel like getting another top fan. Should I maybe turn the side fan from intake to exhaust?
The issue here isn't a real issue. Like I said, temps are good. I just want to discuss it out of curiosity .
