Ok so i got 3 case fans there all 3 pin and have an adapator for molex to plug into the psu. But on the cable from the psu that plugs into the fan it has like 3 molex plugs but then at the end its got a 4 pin connection, do I plug that into the motherboard?
Would that be ok for 3 case fans plugged into 1 wire via the molex connections then at the end of the power cable the the 4 pin connection goes into the mobo? Would that not damage anything?
