Hey guys, getting ready to setup my water cooling and had some questions. Been trying to find info all day but cant really find a great answer so i thought i would ask.
Will be running a 360 rad mounted into the top of my HAF-X case. I just need some input on what is the intake and exhaust.
Should i use the normal setup:
Front/Side 230mm(200mm??) intake
Back/Top exhaust - (bottom to top) 3x120mm -> 360 rad -> top case fans. Turning it into a push pull exhaust.
My problem is, i thought you would want cooler air flowing through the radiator and not the "exhaust" air. Or is airflow just airflow?
I am also running 2x580s in sli. So i was worried that the bottom intake fan would only really be cooling the gfx cards because its basically creating a second chamber in my case.
Let me know if you want any more info on my build
Any input is appreciated
Thanks
Thanks
