- May 26, 2002
AMS gTower. Lots of room for watercooling and very well built.
NavyDood said:If size and price aren't really an issue, then go for this one at Server Case.
This will be my next case. People say that the airflow isn't that great, but there's an answer for that. It's called modding.
Grrrr... Fixed link. Thanks eXCeSS
Nick Burns said:The Sonbata and the 3700 are not the same inside. The Sonata is wider, the hard drives are sideways, and the Sonata is a lot quieter than the 3700.
Definitely go for a case with 120mm fans, and better yet, one with 120mm blowholes. Before I put these in, my case temp was around 35-8C; now it's 21C as I type this!AMD_Me said:http://www.frozencpu.com/cgi-bin/frozencpu/cas-01.html this case from FrozenCPU. Can be dead quiet, offer great airflow.
ZaP37 said:
It's a Pioneer 305S but I don't remember where I bought it. I think it only comes as a SCSI drive.Nick Burns said:Hey Zap, where did you find that slot loading optical drive that you have in that picture? I have been looking for them, but I can't find any.
dude2 said:Hey,
Has anyone got any UK websites where i can get a case.
I am looking for something about £80-£100, little less or little more can be done.
Ideally, i wouldnt mind a removable motherboard tray and many fan slots, but as you have said i want at least 1 if poss 2 120mm fan slots in it!
Has anyone got any reccomendations. Its alot to ask.
Space is also an issue, wouldnt mind having alot of it.
I have a PSU so i want a case without one!
Alot to ask, can anyone come up with anything!? Ive looked for so long
thanks for your time
Jonny
RangerJoe said:I really like my lian li. With 6 stock fan holes, and 2 120mm holes cut in the top/bottom. I highly recommend the lian li' because of their high build quality, ease to use, extremly light compared to chieftech cases, and awesome look. I spent $180 on a case....but it makes it so much easier when I want to change something, to have all the room the lian li's provide. Not only are they wider, but they are a decent amount deeper, so if you have a long video card, you might have problems with hard drive mounting, or IDE cables going to cdrom drives...(brother has a chieftec full tower, and his TI4600 nearly touches his hard drives....)
Deathknight said:
PS: if you are going to consider a Lian-Li there are a bunch of other models other than the PC60 that are nice. The PC-65 comes with a side window and there are some newer versions that have a whole bank of connectors on the front of the case that some may like.
seer33 said:i wish i coudl get a case premodded with 1 120 side, 120 top blowhole 120 exhuast and 120 front intake, is ther any places that can do modifications like ths for you?
