- Jul 29, 2016
Hi all,
Firstly this is how my loop is currently set up.
XSPC Photon270 Res with D5 pump>Motherboard Monoblock>EKWB 420MM rad
CPU: i7 5820k
Mobo: Asus X99 Deluxe
RAM: Corsair 16GB 4x4 2800
GPU: Asus GTX 1080Ti
PSU: Corsair AX1200i
Case: Corsair 900D
So I'd like to change the tubing to hard tubing as it looks a hell of a lot better and also I'd like to add a BitsPower Leviathon Slim 280MM rad at the very front of the case. Hoping to run the fans slower by adding an extra rad.
And this is where I need some help
Is this loop order alright? Res/pump>280RAD>Monoblock>420RAD
Which brand PETG tubing should i go for?
I'd like white coolant this time around, any suggestions?
Lastly, this is my first time doing hard tubing so would this kit be ok? https://www.overclockers.co.uk/xspc-petg-easy-cut-easy-bend-toolkit-wc-357-xs.html
CPU: i7 5820k
Case: Corsair 900D
