Hello , linux enthusiasts
Your help is required with the following problem:
I have written a perl script to parse some text files and i would like to measure the amount of memory it uses in a fashion like the "time" bash command does.
the usage of time is to put it in front of the command you which to execute and after completion it reports the time it took.
For the memory app i would like it to return the max memory used preferably in MB/KB
i have looked at mpatrol but this was for memory debugging and not memory usage reporting (if i recall correctly)
Thanks in advance Ve'R
