- Apr 30, 2008
- Birmingham, UK
So I arrived home from my lecture yesterday to find a puddle of water sitting on top of my graphics card and the computer off (it was switched on when I left it). One of the tubes had come loose that was connected to the CPU block, resulting in half of the water in the loop being poured onto the GPU whilst splashing surrounding components. Even though this is the first time this has happened in 5+ years, I want to give air cooling a go on my main desktop. It looks as though only the GPU died in the process, with some burnt electronic components (tipping the card also resulted in water flowing out of the heatsink!)
I am not really in the loop for current high end coolers, although I would like to keep my current overclock of 4.5GHz with reasonable temperatures (accepting temperatures will be warmer vs my old loop).
The cooler will be fitting inside an Antec 1200, with a width of 213mm I would imagine most coolers shouldn't have a problem.
What coolers would you suggest for the job? Quieter would also be a big plus.
