After having all of my questions answered i decided to make this the calm before the storm. This is the pre-thread to the build log which i will start when I actually place the order for the case, which will hopefully be soon.
So here is the list of every part I plan to use for this build. i will update it as things change and ask for advice on things as problems or concerns arise.
This looks like it will be about a $3700 project give or take depending on prices at the time or ordering, but as of now it is around that mark. So this will really take some time to complete, but I think the end result will be my dream machine. =]
The Centerpiece
Puzzle Box: The Lament Configuration
The Beauty
Case: Ascension CYO
Clear Acrylic
Black Wrinkle Finish
mATX/ATX Motherboard Tray
Side 1 - Big Window Side Panel
Side 2 - Big Window Side Panel
Side 3 - Triple Origional Top Panel
Standard Back Panel
Standard Front
The Beast
OS: Windows 7 Home Premium 64-Bit OEM
MoBo: ASUS Maximus V Gene LGA 1155 Intel Z77
RAM: Corsair Vengeance LP Black 8GB (2 x 4GB) 1600
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz Quad-Core
HSF: COOLER MASTER Hyper 212 EVO (until i upgrade to water cooling)
GPU: SLI EVGA NVIDIA GeForce GTX 670 FTW 2GB
SSD: SAMSUNG 830 Series 128GB
HDD: SAMSUNG Spinpoint F3 1TB 7200RPM
PSU: OCZ Fatal1ty 750W
ODD: ASUS DVD Burner OEM
Additional Equipment
Front I/O: SilverStone Front 4 x USB3.0 Port and HD Audio Ports (Black)
3.5" Bay Converter: SilverStone Aluminum Front Panel 3.5" to a 5.25" Bay Converter
USB Converter: Internal USB 3.0 Male to Internal USB 2.0 Female Adapter Cable
Drive Bay Covers: 5x Mountain Mods ALU (Black Wrinkle Powder Coat) 5-1/4 bay cover
3M Dual Lock Reclosable Fastening Strips
Air Cooling
Fan Controller: 3x Lamptron FC-8
Fans: 20x Yate Loon 120mm Silent
Fan Filter: 6x 120mm Black Aluminum
Fan Grill: 8x 120mm Chrome - Black
Water Cooling
Top/Bot Rad: 2x Black Ice GT Stealth 360 X-Flow - Red
Pump: Swiftech MCP35X 12v PWM Controlled Water Pump - Black
Res: XSPC Laing DDC Reservoir Pump Attachment
CPU Block: Bitspower Summit EF CPU Liquid Cooling Block - Ice Red Acrylic
GPU Block: Koolance VID-NX680 GeForce VGA Liquid Cooling Block
SLI Bridge: Enzotech SLI Bridge Fitting Set - Matte Black
Tubing: Danger Den DreamFlex Value Pack - UV Red (1/2" ID x 3/4" OD)
Clamps: 10x Lamptron Elite Aluminum Reusable 3/4" OD - Anodized Deep Red
Fittings: 10x Enzotech G1/4" Barb Fitting - 1/2" ID Matte Black
Now that i have posted everything I plan to use here are the reason for why I chose some of the things i did.
The 3.5" bay converter is for the 3.5" I/O panel seeing as the case has no front I/O so i fouind something to do the job perfectly. I also got a 3.0 -> 2.0 converter as my mobo will only have 1 3.0 header so I can still use the other ports. Also the 5 drive bay covers so i will probably have the ODD and I/O panel on one side then 3 covers and on the opposite side the 3 fan controllers and 2 more covers.
The Dual Lock Strips will be for mounting the SSD more than likely and possibly the pump to the case bottom somewhere. haven't fully figured that out yet. Won't know final details on that until i get the case and see how everything will fit.
3x 8 channel fan controllers for 20 fans that's 8-6-6. 20x fans for the case including push/pull for the dual 120.3 rads. 5 on the back panel, 9 on the front, 2 rows of 6 and the other 3 rad fans for the front mounted rad. 6 for the top including 3 extra for the top mounted rad. Or back mounted, haven't figured out if i want to mouht the second rad on the back or top of the case yet. Of course the rest are just grills and filters for the visible fans.
The last bit is just all my water cooling equipment I plan to buy. not 100% on the red rads, might go with black, thoughts on that?
The Centerpiece
The Beauty
Case: Ascension CYO
Clear Acrylic
Standard Back Panel
Standard Front
The Beast
Air Cooling
Water Cooling
