- Jan 10, 2012
as one or two of you know I tend to enjoy making a bit of trouble by pushing my skillz at clocking.
well.... I'm at it again and having, shockingly, a bit of trouble.
the current victim is Bassnuts old CHVF-Z with a motherboard block along with my 9590 cpu.
my target at this time is 5.4ghz, 24/7, fully loaded, all 8 burning and a churnin!!!!!!!
I'm at 5.2 and lose one core after 5 hours of p95, 26.6, so a little more work for me to do here.
as you can see my cpu line is hitting 67c.
my issue is that on these boards the vrm can tend to get a bit flaky between 70c and 80c and I have to raise the power frequency to keep it stable, this adds to the vrm temp as it increases the "on" time of the fets which gives me more heat to deal with.
I'm all water, loop order is,
pump-cpu-vrm-480-rad- titan gpu-360 rad-back to pump.
I'm on the fence on adding another rad between the cpu and vrm, I "might" be able to make this work, or going back to air on the vrm as I "know" I can make this work up to 90c.
