- Dec 31, 2006
- Laval, Canada
Hello everyone,
I'm coming back to the scene after about 10 years of being away. Last time I did WC was with my AMD Sempron!
Since I've been away for a long time, things have changed so I've read all the sticky. Problem with them is, well, they are dated as well. Good for the theory, but the part listing aren't always good. Because of that, I'm requesting your help.
My setup is as follow:
Case: Antec Twelve Hundred v1
Board: EVGA x58 3x SLI Classified
CPU: I7-920 @ 4.2ghz
GPU: EVGA GTX 480 (planning on making a SLI)
PSU: Corsair HX850W
Now, I'm looking to liquid cool the cpu, both gpu and the north/south bridge (gotta check which one, I know one of them get really hot with OC, my last one burned).
I don't care about putting the radiator outside of the case (the case have hole for that anyway). I'm wondering if I should do 2 loops or 1 loop. Although 2 loops would be the best, space in the case would be missing for all of that (would be very tight).
Now, looking at some website found in the sticky, it's seems I'm late for the party. I can't find those EVGA x58 north/south bridge waterblock and I'm unsure which waterblock to pick for my geforce and cpu (I was looking for the EK HF one, but they aren't listed anywhere).
As for rad, I though maybe putting 2 rad with one loop? I would replace the 200mm fan on top with a rad and put another one outside the case, the loop would be res->pump->CPU->NB->RAD->GPU->GPU->RAD->res.
But then again, even with the less restrictive RAD, I think this would be too much for the pump?
Thanks everyone for your help!
PSU: Corsair HX850W
