Okay, I'm helping a friend build his first computer, I helped him pick out the parts, but I love running it by you guys to see if theres anything i've missed or any better choices I'm not taking advantage of, or to see if something isn't compatible with another item that I was too stupid to notice.
This is a Budget computer built for heavy mmorpg gaming. Games like SC2 and Diablo3 would need to run on it well.
I did the best I could in choices based on his $750 budget.
Case: About $100
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Power Supply: About $90
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Motherboard:About $65
ASUS M4A785-M AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131595
Memory/Ram: About $70
CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model TWIN2X4096-6400C5C
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145241
Processor: About $77
AMD Athlon II X3 445 Rana 3.1GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103872
Hard Disk: About $60
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
Video Card: About $??
(Not Seletcted - Were still looking, about $125-$200 budget or so... Any Suggestions?)
Again, i'm pretty sure everything is compatible and will fit in the motherboard correctly, it should all be the correct sockets and all.... I'm hoping I did this right
Thanks in advance for anyone willing to give advice on this build!
Case: About $100
