- May 25, 2003
- Basking Ridge, NJ
Standard Zalman approach: Make things ridiculously large enough that a fan is not required, make them out of expensive copper, and then polish everything until it looks beautiful.
This will probably be a quality product, as are most things from Zalman. This will probably not really be the overclocker's best freind, as passive cooling tends to be "good enough", but not something with a lot of thermal overhead, and not as good as something with a fan. This is seen in Zalman's passive VGA cooler - sure it's quieter, but chances are you won't be able to overclock your video card as high as you could with a good CPU HSF modded on.
The exception to Zalman's general rule of really big but just good enough, though, is the CNPS-7000 HSF - it is more than good enough (and more than heavy enough...). So, maybe this case will be more than good enough; I'm sure we'll find out eventually.
Two things are for sure - it looks really nice and it looks really expensive.
P.S. - I can't find the link anymore, but I read a review of the Zalman passive heatpipe HDD cooler - it took the operating temp of a 15k RPM SCSI drive at load from 60+ degrees down to somewhere in the 40's. Pretty sweet.
