- Jul 9, 2010
Hello, I've been running WCing for about a while now, and I'd like to begin using compression fittings.
I have the Danger Den MC-TDX waterblock on an Intel E8500, as well as this waterblock on the north bridge.
I'm using Tygon 3603 tubing, 1/2" ID, with a 1/8" wall. These I believe are the correct fittings.
The only problem is that I don't think two of those fittings will fit side by side on either the CPU block or the NB block. I am looking for suggestions on how to fix this. Should I use a few 45 degree adapters? If so, which parts would be the correct ones.
Thanks for the help. If you have any questions about my setup, please don't hesitate to ask.
Cheers.
Cheers.
