Kebabninja
- Apr 11, 2016
Hello
I am having a problem with a friends computer.
From what I have experienced there seems to be is a communication error with the harddrive, causing erroneous writes and corrupting of files (Windows 10 64bit).
MOBO:
Gigabyte GA-Z77X-D3H
I will give you the timeline:
When first received, the old HDD was unresponsive, it was not even detected in the BIOS. He purchased a new for me to install.
The first success came when I simply put the HDD in my own computer and formatted and installed from there. Once the install was finalized I could move the HDD back to his computer and successfully boot, and everything was running fine and fast. This is where it got weird:
After installing various standard programs I got a BSOD after 2 days of tweaking (no OC or other BIOS tinkering). After rebooting it said the windows install was damaged and that I had to reboot onto a windows 10 disc for repair.
I moved the HDD to my own computer again to reformat and install, but was able to actually boot now, and it appeared to do an automatic repair. I moved the HDD back into my friends computer.
A day later it suddenly become VERY slow, and the HDD arm can be heard physically moving around in a frantic search back and forth, like a typewriter. It also made this sound when I first received it, with the faulty HDD. It went from 20 second bootup to 5 minutes, and it takes several minutes to open the most basic programs. Then it failed completely, and now again, it cannot boot. Saying "Automatic Repair Couldn’t Repair Your PC". All drivers are up to date.
Does anyone recognize this behaviour? It appears as if the computer makes write errors and messes itself up more and more, regardless of what I do, and how many fimes i reformat.
MOBO:
- I installed the new Seagate Barracuda 1TB, but windows 10 64bit installation fails in the second step where a reboot is supposed to occur. It cannot boot and says different things, one being "winload.exe" is missing from system32. Other times it was other files.
- I attempted to put the HDD in a SATA3 (is it SATA3?) instead of a SATA6 connector, no difference.
- I attempted to install SATA drivers from USB prior to win install, no difference.
- I flashed the BIOS to the newest version, no difference.
- I tried making a new windows 10 boot USB, no difference.
