I am building a computer for my dad. It has these components:
AMD Athlon FX-55
Epox EP-9NPA+ Ultra
512mb x 2 DDR400
Antec 350-watt PSU
BFG 7600GT PCIe
Plus all of that other stuff.
Here's the problem. It won't frickin post. Originally I had it running with the exception of an X300SE just for some games for a friend who was coming to play GTA. I had a different chipset cooler on it, and it was running out of case.
Then I took it down and rebuilt it in a case for my dad. It wouldn't POST inside the case, I would press the power button by using the little switches on the motherboard and it would turn on for about 15 seconds, then just turn off.
The motherboard has a diagnostic LED display which would display 'FF' the instant it would shut off, which meant that it was attempting to initialize the boot phase.
Now, I thought it might have been shorting out do to a standoff gone awry or something, so I took it out and placed it on a box and it would POST. I thought, "Problem Fixed, just place it back in the case.". So I did, except it wouldn't POST again, so I took it back out, and then it would never POST again. I started smelling to see if something had burned out, and I noticed a very faint burning, smoky smell, but I just thought it was general hardware usage smell.
THEN, I noticed that the chipset cooler was not on all the way! One of the little plastic clips which goes into the hole in the motherboard and then spreads out on the other side was popping up, and it was broken. Oh noes! I thought maybe the chipset was overheating and shutting down before it had the chance to do anything. So I re-attached the cooler, pressing down on the both sides to make sure I had excellent pressure and contact, then pressed the power button. Still NO GO.
I tried swapping Video Cards, double checking the CPU/HSF contact, swapping around memory sticks, tried a different PSU, unplugged all hard drives and optical drives, reset the CMOS, NOTHING!
It's driving me insane, I don't know what is wrong with it.
Help would be GREATLY appreciated.
Thanks!
Edit: Too angry to notice that emotes don't work in the title. I am an idiot. Argh.
AMD Athlon FX-55
Epox EP-9NPA+ Ultra
512mb x 2 DDR400
Antec 350-watt PSU
BFG 7600GT PCIe
Thanks!
