Is this better than a H100 AIO Water system? As it stands my system steps up to 4.1GHz when the CPU loads are 70-80% used, I think its called Turbo or someting. It is a setting in the BIOS. I did try 4.5 but the temps hit 90c and I don't like my CPU being that hot.
In that case. I would recommend going with the 212 or something similar.
If you find you want to go further after that, you should probably look for a new case and really think about how far you want to take it..... full custom WC, etc.
If he decides to go custom H20, I would advice he reads up and understands what he's getting himself into. Than make sure how much heat will be generated into the loop and how much heat surface will be needed, than he should look for a case to fit all that in.
