i need a miracle substance. Much like copper paint (rear-defrost repair) only rubbery.
Bad power connection inside the laptop. not on the board, its the center pin maing bad contact with ground.
Cant solder it for the life of me, but i can paint on it. ive used the rear defrost paint a few times, but it just dries and cracks off. (which cant be good, letting those conductive paint chips float around...)
i need something thats gonna STAY, and conduct electricity. ive tried a few so-called copper compounds, apparently none of them are conductive. Conductive epoxy would probably do it, but its a bit solid and might crack off... so the best thing i can think of is conductive paint on rubber.
Does such a material exist at a reasonable price? i cant stand holding this power plug at just the right angle anymore.
