- Oct 28, 2010
- Toronto, Ontario
I've been trying to nail together a watercooled system. I'm going to use watercooling on my CPU and 2 GPUs. I've been reading different guides all nights and asking questions in a couple of forums, still I can't seem to get a straight answer.
These are the parts I've chosen so far for my watercooling kit:
Radiator: http://www.jab-tech.com/Black-Ice-GTX-360-Radiator-pr-3613.html
Pump: http://www.jab-tech.com/Swiftech-MCP-355-12v-DC-Pump-pr-3510.html
CPU Block: http://www.jab-tech.com/EK-Supreme-HF-Full-Copper-pr-4790.html
Reservoir: http://www.jab-tech.com/Swiftech-MCRES-Micro-Rev-2-pr-4312.html
Tube: http://www.jab-tech.com/PrimoFlex-Pro-LRT-UV-Green-Tubing-1-2in.-ID-X-3-4in.-OD-pr-4595.html
Compression Fittings: http://www.jab-tech.com/Bitspower-T...-Fitting-1-2-to-3-4-BP-SLCPF-CC5-pr-4400.html
Coolant: Distilled water.
Biocide: I don't know where or how to get some, but I've heared that Kill Coil is good.
The problem I have right now is that I don't know how many Compression fittings I'm going to need, or if I need any at all, or that if I should get barbed fittings instead.
I would really appriciate it if someone would clear this up for me. Thanks.
