- Jan 25, 2012
- Bean Town (A.K.A) Boston Ma.
Hello, I am new here just signed up. I have come across this site many times while looking information up. So this time I figured I would join . So I followed this Notices tab here and clicked the first link so I hope this is in the right section.
Okay, As of now I have been sucked into wanting to build a new PC and go liquid cooled. I have NEVER done a setup like this. I have always just stayed on air riggs. It's time for me to evolve I guess but at the same time I am not trying to build a 10k PC lol.
So, as I am SURE most of you on here have heard and seen the same questions over and over and if so I do apologize but again I am a FULL noob when it comes to liquid cooling
So I know information is a big part so I hope I can give enough. First I will do a parts list. Then ask a few questions I will DO my best to keep them at a minimum
Parts List
Case - Corsair 800D Obsidian
Motherboard - MSI Z68A-GD65 (G3)
CPU - i5-2500K Sandy Bridge 3.3GHz ( will be OC to at least 4.5GHz )
RAM - Corsair CMZ4GX3M1A1600C9B Vengeance 4x 4Gigs = 16Gigs
GPU - EVGA GeForce GTX 580 FTW Hydro Copper 2 Video Card - 3GB, GDDR5
PSU - Corsair CMPSU 1200Watt ATX
RAD - XSPC RX360 Triple 120mm Radiator Rev 2.
REZ - FrozenQ PC Mods 250mm Liquid Fusion V Series "2nd Generation"
PUMP - Swiftech MCP655-B 12v Water Pump w/ 3/8" Conversion Kit
CPU Water Block - Koolance CPU-370 Liquid Cooling Extreme CPU Block
Tubing - 1/2" UV Blue DreamFlex Tubing
Fluid - I am still researching that one lol. Heard a lot of good and bad with certain fluids.
Screen - Not to sure yet but I am looking at a 28 inch 1920x1200
Fittings - This is where I get stumped I would like to use compression fittings. But I am lost as to the sizing and style I guess you could say. Looks wise I am going to go black but I am a little confused as to HOW some hook up to the GPU and so on. I have noticed some just push into place and that makes me a little nervous. Again, I am new to this so I may just be over thinking and missing a very simplistic answer on my own lol.
Fan Controller - Scythe Kaze Master Pro Ace
Fans - Scythe Gentle Typhoon AP-15's
So that's what I was going to try and work with so far. I was trying to keep it some what simple. Just 1 loop for my CPU and GPU. At first I was thinking of getting 2 of the GPU's I listed but some have said I would need another loop for JUST the GPU's. And, I have also read that with the right fans and with the RAD that I am going with I could pull it off with the 1 loop as long as I have the right pump for the head pressure.
Meaning, just in case I lost any one.
1 loop from PUMP > CPU > GPU > GPU > RAD > REZ > repeat.
For my first build I really do not want to try a second loop for 2 GPU's so I am thinking that ONE of those GPU's should handle some games well.
Example: Crysis 2, Metro 2033, MW3.
So I am thinking PUMP > CPU > GPU > RAD > REZ > repeat.
Now as for the order of cooling I am not to sure. I have read some say it doesn't matter the order, some say cool GPU's first because they generate the most heat then cool the CPU. (But from my understanding a GPU can handle more heat the the CPU so for me I am going with cooling the CPU first then the GPU.
I will also be doing sleeving on my PSU. I just do not know if I am going with MDPC or Para Cord. I have used the MDPC sleeving many times but I was thinking of trying out the Para Cord. I have seen some really nice jobs done with it.
A note on the CPU of my choice. I LOVE AMD, but at the same time I'm not sure if I should stay with that 965BE Phenom II x4 or if I should go with a 6 core. I know some say 6 cores do nothing for gaming really but it got me thinking. nVidia, using PhysX. Now I read that a lot of it still gets dumped on the CPU without using another card SLi mode or at least have a card for PhysX. If this is true then why not move to a 6 core CPU?. I am however not to sure how it effects even a 4 core but it was something I was thinking. I need to do a lot more reading on that.
Parts List
