Asperatis,
I built a water cooled system in a Corsair 900D case back in June 2013 with the following components.
http://www.overclockers.com/forums/...ter-cooled-Haswell-build-seeking-advice/page2
The basics of the computer are:
CPU: i7-4770K (upgraded to 4790K now)
MB: ASUS Z87-PRO LGA
Grpahics: two EVGA GTX 780 Hydro Copper in dual SLI
RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB)
Corsair 900D
SeaSonic X-1250 80 PLUS GOLD
The water cooling components:
Swiftech MCP35X 12v PWM Controlled Water Pump
- Optional Tank Res
- MCP35X-HS Pump Heatsink
- Yate Loon 80mm x 15mm Fan
Coolgate Quad 120mm Ultimate Heat Exchanger Radiator (CG480) x 2
Koolance CPU-380I Intel Liquid Cooling CPU Block
PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD - Clear
Koolance Coolant Temperature Sensor Plug x 2
Bitspower Matte Black Sealing Plug For ID 1/2" Tube x 2
IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip x 2
1/2" ID UV Reactive Leakproof T Fitting x 2
Phobya Reusable 3/4" OD Hose Clamp - Black x 22
Gentle Typhoon fans AP-45 (in pull) x 8 (2150 rpm)
Sunbeam PL-RS-6 Rheosmart 6 Fan Controller 5.25" Bay 6 Channel 30W Fan Controller Panel (have 4 fans on two channels)
