- Jul 6, 2016
I've been trying to figure out what's wrong for a while. Some games I was experiencing occasional crashes. Some games I would experience artifacts displaying on the screen. Sometimes I would turn down the GPU clock, other times, I would increase the power limit and/or the voltage. Some games, I would only experience artifacts. Other games, like Witcher 3 (what I've been playing exclusively this past week or two), I experience fairly consistent crashes, and sometimes artifacts too. Sometimes it's more obvious and/or more often than other times.
It doesn't seem to matter what tweaking I do; I feel like I've tried every setting between 0 and infinity, and nothing seems to change anything. I've tried what I thought was my max stable OC and that mostly worked in all other situations, and I've tried playing with no OC whatsoever. I seem to notice the problems more often after I've been playing for a little while, which initially sounds like maybe an overheating problem, except that I've got a great system, and my GPU never runs more than ~72C. I've been playing with my video settings turned up on Ultra; every setting is as high as it will go. Even with these settings, I always run at 60 fps...so I am not lead to believe that the settings are set too high for my card. I maintain this fps even with the card not OC'd.
My system is an i5-6600k, OC'd to 4.5GHz, and a GTX 980. All temperatures across the board are phenomenal. CPU stress testing indicates that it's very stable. Everything points me to think it's the GFX, but what specifically, is well beyond me. I am new to these forums, and new to this age of technology. I've built many systems, but the last time I built a system was roughly a decade ago. This is the first time I've ever OC'd something, or had such a top of the line system.
If I left out any information that might prove helpful, please let me know. I really value stability, far more than getting every last ounce of juice out of my system, so you can imagine that this is really bothering me. I've spent some time on the forums and internet searching for a solution, but I could not find anything specific to my problem. I originally thought it must have been an OCing problem, because I'm such an amateur, but after still experiencing the same problems even with no OC, I don't know have a clue anymore.
Thanks for your time and help.
