- Apr 3, 2012
- Barberton, OH
Actually your real temperatures are probably close to 72c
ASUS's motherboard sensor is about 4c low at load.
Great, thanks.
When I had my Vcore to Manual past 4.2V, the heat would keep on rising past the 60 degrees core package. Even if I do have a water cooling system with push/pull fans and 4 x 200mm fans... Hmmm... I will try to see the max stable with 4.15V...
Also, CPU temp shows idle at 40degrees, then jumps past 80 degrees with Prime, while CORE PACKAGE idle at 18 degrees, then stable at around 55 degrees with Prime.. Which one is the correct temp to watch out for, when AMD states the max temp for fx-8150 is 61 degrees...?
Urgh.. I was stable 4.3 with my TX650, but then the PSU got REALLy noisy so I changed to a HX750 and since then, the PC doesn't go to sleep anymore and sometimes hangs after a couple hours @ idle..... i'm tired of having these issues
It is set to 'high power', with 'sleep' activated; I do have 2 roomates, which is why I also have 'password required at wake'...
Hmm.. could you kindly be a little more specific on what are winders ? And is there a fix ? Thanks
