What do you do that would require a 14 core 28 thread CPU?
I do file conversion like video and audio, definitely gaming, etc. and really have no need for the full capability of the 6 core 12 thread 8700K I am running.
Especially running the most demanding games I run maxed out no problems.
So what do you need those extra cores for, and in your opinion is it worth what it costs?
If I had one, it would definitely be under my chilled water cooling.
But for what I can overclock the 8700K to and get out of it, there's no way I would pay over a grand for just one CPU.
For the record if I was going to run something like that I would simply modify my chilled water cooling to handle more TDP.
That's what's so flexible about my setup it is modifiable.
You may or may not know this, but if you can run a CPU below it's TDP ambient design parameters it does not pull the spec'd TDP it is rated to be pulling at lower temperatures.
But anyway you look at it 14 cores is 14 cores!
And no matter how good your overclocking skills are there is going to be heat to deal with, and the cooler you can run it the better.
Quote Originally Posted by EarthDog View Post
You have less than half the chip I'm running. Id be curious to see what temps this thing would actually get under your chiller.
You may be curious about it, but there's only one way for you to find out, which IMO shouldn't be a problem for you since the CPU you bought cost more than what I have in my chilled water peltier cooling setup.
But knowing you up to this point I would venture you posted for some punchy reason, with zero validity.
Which is usually what you do anyway.
Though my chilled water cooling may seem absurd to most, with even main stream CPUs getting more and more cores, and especially with what you are running, and also with CPU dies shrinking with each new platform release.
Chilled water cooling may very well be the norm in the future, and at least for me I have a head start.
From the very beginning of my Chilled Water Cooling experimentation back to version 1, I have been seeking improvements in overall size, and electrical use, and I am still seeking both of those to get the setup shrunk down even more than what it is now.
Today it is more accommodating than ever as far as overall size and power used to run it, and Lord Willing will get even better.
I'm curious EarthDog, What do you think a 10c ~ 12c actual coolant temperature could do for your setup?
