mrmagoo1077
- Feb 25, 2014
Picked up this computer cheap, used. Currently my core i7-860 is being cooled by the stock intel cooling unit. Prime 95 blend test sends the CPU temp to 94'c without overclock (2.8ghz stock)! Even a mild overclock to 3ghz puts the temp close enough to tl max that I shut the test down immediately. Ideally I would want the prime95 not to exceed 90'C
Im not looking for crazy overclocking speeds: 3.2ghz would be my ideal and 3ghz would be acceptable.
My friend has a spare cooler he would just give me, and im unsure if it's any better than my stock intel one: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6624654&CatId=798
My budget is maxed atm. Would this cooler be an upgrade at all?
