Hello,
At my work there are 120 1U servers, based on a mini-itx motherboard, equipped with 3 hard drives and an ssd, and an Intel Atom processor. When the casing is open, and the computers are installed in every second slot in the rack, all is well and the CPU works fine even with the fan removed, with only the radiator. However if I install the computers tightly, 40 per rack, the heat is so great the processors shut down. I tried rearranging the components a bit, but it does little help. Could you please recommend some small but strong fans or cooling techniques to increase the airflow thru the casing? Attached are a couple of photos of the computers. Thanks in advance for any help.
