hannibalxali
- May 9, 2020
I want to add a noctua 200 to two 240 full copper radiators using custom mountings. Springs from each corner of the fan to the outer corners of the Radiators with suitable screws to fix it in place. My only concern is about the difference between a one 200 mm fan and four 120 mm fans regarding efficiency. Knowing that:
200mm has a 150 CFM, direct contact area is π x r² » π x 10 = 314 Sq cm
120mm has a 107 CFM, direct contact area of four fans is 4 x π x r² = 452 Sq cm
I just multiplied the CFM by the area affected to determine the difference between both methods:
200mm ». 150 CFM x 314 Sq cm = 47100
4 x120mm »107 CFM x 452 Sq cm = 48364
I don't know what are the final numbers but i think that they determine the difference between two methods.. Are my calculations correct? If they were correct then there will be no difference regarding cooling performance. But way less noise with the big fan and probably a better performance in real life, plus the easier control with just one cable and less power consumption of course. Thank you for reading and answering Please see the image provided
