- Mar 6, 2013
Hey all, quick question that I wanted some advice on. I am running a 3570k @ 4.5, 1.2v. Idle temps are around 28-38c, and on load w/ IBT I can easily get over 90-95c.
Currently, I am using an AIO Thermaltake Water 2.0 Performer. I have checked the cooler multiple times to check if its seated properly and even reapplied thermal paste, but the temps still stay around the same. I do plan on building a completely custom WC loop in the near future, so I am sure the problem will be fixed then.
Should I buy a heatsink for now instead of the AIO or just wait a lil while to build the WC loop? I plan on getting a Hyper 212 or a V8 since I have a store that sells em for fairly cheap around here.
I am just worried about the chip getting too hot, gaming gets me around to 70-75c which I feel is a little too warm for use hours on end.
Thanks in advance for the help guys
