Foxie3a said:
thermal compound is not electronically conductive (mostly) and I am not putting it on the wires or anything!
Foxie3a said:wouldn't having thermal compound on a chip let the heat come off of the chip faster, then the air can cool the compound?
No. The compound is not some sort of magic heat absorber. A layer of compound on a chip will never be warmer than the chip itself, so for the same surface of contact with air, it won't cool as much. The chip might actually end up warmer than without the compound.Foxie3a said:wouldn't having thermal compound on a chip let the heat come off of the chip faster, then the air can cool the compound?
Don't know if that means there is 88% silver or 88% goop with <=22% silver. Not sure exactly what Conductive Filler reffers to.From AS5 website
Arctic Silver 5 contains over 88% thermally Conductive filler by weight.
Foxie3a said:OK, I got it now..so sanding the heatsink would be very good, so then you could use much less thermal compound, right?
Foxie3a said:and what is lapping again?
Foxie3a said:so using 800, 900 then 1000 grit sandpaper in a row? for example.
hawtrawkr said:a lapping disc is part of a kit you would use to lap a cpu or hs with
its usualy better to use than sandpaper because of the motion you use it with
kinda like when a carpenter needs to plane a door down and goes from one side to the other with the plane with paper people tend to want to make circular motions over the top but that can concave the surface your trying to flatten
