- Jun 17, 2010
- Marietta, GA
their new 1200w one is by a new company (for corsair), flextronics...i don't remember the old one
Got the ECO installed. Yes the radiator lines are a little stiff but they bend easily enough to get them out of the way. So far my idle temps have been pretty the much the same as the T120E (push/pull). I do realize the temp diodes are not all that accurate but I did not expect to see the same variance in the core temps. It was the same with the T120. I am questioning whether or not I have the h/s seated properly because of the variation in the core temps and I use the pre-applied TIM. The 3pin & 4pin connector for pump power and fan could be a couple inches longer imo.
I did run prime95 for a bit not 15 mins yet, and the highest core was 55c for about 5 mins. It did take quite a while to recover however. I will pay more attention to recovery time when I do tests with the stock clock.
Here are the stock temps
Core 0 = 40c
Core 1 = 33c
Core 2 = 38c
Core 3 = 35c
More to follow.
I have an i7 920 4.4 ghz overclocked and i would like to know if the cool it eco c240 can handle the temps down
\The pump is plugged into a 3 pin header set to 100% and the fan is plugged into the 4 pin CPU fan header. I am also using HWMonitor and the pump is spinning at 4200ish rpm. I did notice that the TIM was a little off center. I am going to reseat the pump and apply some other TIM. I only have the shietsu (spelling may be wrong) pads. I can find my little bag with the other stuff.
did it seem stable there at 15 mins? I know real water takes longer to stabalize, but idk how these faux water systems do.
@pleadguitar, is your avatar a schecter hellraiser?
I think that the temps should be dropping immediately, are you sure the fan control is setup right?
